Cranks but will not start
225,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
BEARDBOSS
I have the 1500 model, v6. It had been sitting for a month or two was ruining fine but now it will not start. It turns over, I have a new battery, spark plugs, spark wires, rotor, rotor cap, and starter. I did check fuel pressured it is at 60 steady can also hear fuel pump cut on when turning switch. I also saw online about replacing the igniting switch. I have not check fuel regulator. Anything else I am missing? Thanks in advance.
Aug 17, 2018 at 12:49 AM
Good morning.
Did you check for spark at the plugs?
If you have fuel pressure then you need to see if you have spark.
Aug 17, 2018 at 1:15 AM
