cranks but wont start
147,000 MILES • 5.0L
TAMMY ADAMS
was driving down the road n it just died/stalled n has not started since when u turn key it cranks but will not start sprayed with ether n it started for a second thats all twice have replaced cap rotar coil n camshaft position sensor check fuel filter relay n all fuses plugs n wires all are good
Aug 28, 2016 at 3:42 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
Aug 28, 2016 at 4:10 AM
TAMMY ADAMS
cant do code scan no transportation now n pressure was good
Aug 28, 2016 at 9:27 AM
HMAC300
  • 48,601 POSTS
fuel pressure should be 60-66 psi you can get a cheap scanner at auto parts also try another key it may be security system not a new key otherwise you'll have to have amechanic scan for codes to see if it's a security problem or what
Aug 28, 2016 at 11:37 PM
