Cranks but will not start?
2017 DODGE GRAND CARAVAN
95,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JMCCAULEY0809
The van will crank but won't start. the fuel pump's been replaced, and the fuel pump wiring harness has also been replaced. all the fuses are good and everything else.
Dec 11, 2022 at 4:35 AM
  • 110,244 POSTS
In most cases, a crank no start condition is either the result of a lack of fuel or loss of ignition spark. Did this happen all at once or were you having issues prior to this?
First, take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/car-not-running-advanced
Also, I need you to try something. See if the engine will start if you use starting fluid. If it does and then stalls, we know it is a fuel-related issue. If there is no change, we likely have an ignition spark to the plugs issue.
If that is the case, here is a link that explains how to test for spark to the plugs. Try this and let me know the results:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Dec 11, 2022 at 11:04 AM
JMCCAULEY0809
Yes, it will crank then shut off. I used starter fluid from what I've been researching I believe it's probably the relay.
Dec 11, 2022 at 11:41 AM
  • 110,244 POSTS
You can check the relay. Here is a link that explains how it's done. Also, if you find the relay is good as well as related fuses, then we need to check the fuel pump pressure and the fuel injectors.
Let me know if the relay takes care of the issue.
Dec 11, 2022 at 1:06 PM
JMCCAULEY0809
Where is the fuel filter located?
Dec 13, 2022 at 7:54 AM
JMCCAULEY0809
Will the fuel level sensor cause the van to crank but not turn over?
Dec 13, 2022 at 7:55 AM
  • 110,244 POSTS
The fuel filter is integral to the fuel module in the fuel tank. As far as the level sensor is concerned, that won't prevent it from starting.
Have you checked the fuel pressure? If not, here is a link that explains in general how to do it:
You will need a fuel pressure gauge, but most parts stores will lend one to you.
If you have checked the fuel pressure and it is good, then we need to check if the fuel injectors are getting power from the ASD relay.
If you look at pic 1 below, I highlighted a fuse to check and the relay. When you check the fuse, confirm there is power to and from it. As far as the relay is concerned, switch it with a different one having the same part number. If there isn't one, here is a link explaining how to test it:
Also, here is a link you may find helpful when testing the fuse:
Next, if the relay and fuse are both good, turn the key to the run position. At each fuel injector there will be a brown wire with a white tracer. Confirm that color wire is getting power at each injector.
Let me know what you find.
joe
Dec 13, 2022 at 12:07 PM
