Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lexus
RX 350
Engine
Symptoms
Not Running
Cranks but will not start after overheating
2008 LEXUS RX 350
179,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
FORRANDY3
MEMBER
1 POST
After overheating car never wanted to restart again.
May 12, 2021 at 12:28 AM
Experienced Mechanic
This sounds like we have a compression issue.
Here is a guide that will help with this in general:
https://youtu.be/dCjmRL3p4Cs
However, I would start with testing the compression using this guide:
Also, you can test the head gasket as that would indicate the issue as well.
Let's run through this info and go from there. Thanks
May 13, 2021 at 11:09 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Air Conditioner — Not Working
Engine stalls while driving
