Engine cranks will not start
207,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
STORMIECOCKERHAM
I replaced the crankshaft position sensor, oil pressure sensor and also the fuel pump. After replacing the pump, it ran fine got in it today it turned over started and shut off shortly after. I have no codes popping up and now it won’t start. I gave up searching for the problem went out about an hour later turned over and started right up and died before i could do anything else. I’m at a loss here. Not sure what to do next.
Mar 15, 2022 at 2:17 PM
Good morning,
The first thing I would do is check the fuel pressure to be sure it is within specs. Keep it on and see what happens when it stalls. You could have a bad fuel pump.
https://www.2carpros.com/articles/car-not-running-advanced
Mar 15, 2022 at 10:18 PM
