After replacing the head gasket the engine shut off while driving and will not crank or start?
229,155 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DUTCHGIRL
  • 17 POSTS
I just replaced the head gasket on my car, and it drove for just a little bit then cut off. It cranks but won't start. I've checked the battery, starter and alternator, all good. All fuses and relays are good. Sensors are good. Car is throwing no codes. What should I check next? Thanks in advance.
Apr 25, 2023 at 5:49 AM
  • 55,746 POSTS
Does the engine run on starting fluid? Also, how does the engine sound when you are cranking it over? Can you upload a short video of the engine cranking so I can hear it?
Here is a guide to help us see what's going on and get the car fixed:
https://www.2carpros.com/articles/car-not-running-advanced
Let's check for spark as well.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Please go over these guides and report back.
Apr 27, 2023 at 2:49 AM
