Cranks but wont start
NHANDZEL
  • 1999 OLDSMOBILE 88
  • 110,000 MILES
I am helping a family member with this car. The car was running fine and one day while driving shut off. The car will crank great (confirmed at least 12v battery) but will not start. Using a spark tester all 6 plugs are getting spark. Tried starting fluid and it acts like it wants to run but never fires up. We've replaced the crank sensor with no luck tonight. I cannot find a troubleshooting flow chart or a FSM for this vehicle online, hope you guys can help.
Thanks!
Nick
Saturday, May 18th, 2013 AT 8:13 PM
HMAC300
  • 48,601 POSTS
Cross A&B on aldl watch service light to get codes flash e s3times for one number then 3 for next 1=2+12 check fuel pressure 41-47psi look for trouble codes on site here under OBD1
Sunday, May 19th, 2013 AT 8:03 AM
NHANDZEL
Thx for the quick reply, used an obd2 scanner to verify no codes present. I will check fuel pressure and get back to you
Sunday, May 19th, 2013 AT 8:41 AM
