Cranks but will not start
20,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DESERTLADY
  • 9 POSTS
After the car sits for one to two days it will start and run one time. Can hear the fuel pump working, put a new relay in the fuel pump space. After market security disconnected. It acts like it will almost run maybe a second or two, but like it is out of gas and it has gas for sure.
Sep 22, 2017 at 1:32 AM
SATURNTECH9
  • 30,869 POSTS
When the car does not start with the key in the run position is the security light on solid or flashing on the dash? Also, have you checked for codes in the computer yet?
Sep 22, 2017 at 6:22 AM
SATURNTECH9
  • 30,869 POSTS
When it does not start is the gas gauge key-less entry power door locks etc., inoperative?
Sep 22, 2017 at 6:23 AM
DESERTLADY
  • 9 POSTS
The security light does not blink,it is on solid. Also, door locks etc., all continue to work with the key on. Thanks for your continuing help with this.
Sep 22, 2017 at 2:09 PM
SATURNTECH9
  • 30,869 POSTS
If the security light is on solid when it will not start then the security system is keeping it from starting it is disabling the fuel injectors.The nest thing to do is have the body control module scanned for codes get the exact code numbers not code descriptions. It will take a professional scan tool to do that.You could have a bad pass lock sensor which is part of the steering lock housing.
Sep 22, 2017 at 3:58 PM
DESERTLADY
  • 9 POSTS
Thanks so much, I will go rent a professional scanner and get code number from the body control module and let you know. thanks again, Audrey
Sep 23, 2017 at 4:07 AM
SATURNTECH9
  • 30,869 POSTS
Sounds good keep me posted.
Sep 23, 2017 at 6:37 PM
DESERTLADY
  • 9 POSTS
Hi I did go get a scanner 100.00 from auto zone as california won't allow them to rent them anymore.I have never used one before but it said OEM enhanced live data is not supported by this vehicle. Also said Class 2 Data Link Malfunction. U1000 (1/44 Not Passed S C ). I think I'll start at the very beginning about a month ago one day all my warning lights started reading wrong- like out of gas, overheating to the top, I went to an electrical shop he said it was the after market security, that they do a couple a week-he discounted it or removed it?? and came to me and said it didn't fix the problem-maybe in the original factory security in the computer. It drove well so I just keep driving it like that for a few weeks and the gauges would change at will. I actually was on my way to auto zone to get a scanner check from them, turned it off before i had got there and cranked good and like tried to start ( like run a second or two) but would not start, towed it home. Since than I've tried alot, but what I wonder about is during this time of no start it started up one time I drove it around my house etc. ran great until I turned it off and has not started again since. It has gas, spark to the plugs, can hear fuel pump come on and humm. It still will sometimes run like a second and I give it alot of gas but won't keep running. I have many ,many times did all the security tricks, now mostly the security light comes on solid, in about 2 or 3 seconds it goes off and other warning lights go off with it. I believe my friend that first checked everything said injectors won't getting anything. I did replace the fuel pump relay and check the fuses.I was told it is most likely a body control module but since they are rather expensive I really wanted your opinion- especially since it started once and almost acts like it's going to start but not getting gas. Thank you alot for your help-Desert Lady
Sep 27, 2017 at 10:07 AM
SATURNTECH9
  • 30,869 POSTS
Does the gas gauge and temp gauge work now that it won't start?The gauges changed at will like the gas gauge and temp gauge?You didn't open the scanner yet did you?
Sep 27, 2017 at 3:56 PM
DESERTLADY
  • 9 POSTS
Hi, thanks for responding. The gas gauge and the temp gauge do not work. I returned the scanner. I just went out to check the gauges right now after I got your message and I can't believe it the car started, however the security light is solid and staying on and little square to the right of it with a down arrow and like a little river under it stays on, airbag light staying on and showing out of gas, but there is gas in it. It has always sat for quite a long time when it starts like this. I've left it running to charge the battery and cause it sounds so good-ha. Thank you so much for your help. Desert Lady
Sep 27, 2017 at 4:43 PM
SATURNTECH9
  • 30,869 POSTS
You have a bad body control module that's what it sounds like it to me I have replaced a ton of them on that car.with those symptoms.
Sep 28, 2017 at 4:03 PM
DESERTLADY
  • 9 POSTS
Thank you so very much for all your help. Actually the car is always starting now but gas gauge, temp gauge and security light all still just staying on. will a body control module fix that?? Is that what controls all those dash lights? Thanks again, your help has been immeasurable to me . I have never worked on my own car before and am 75 yrs. and did not have money to have a a very expensive mechanic maybe? fix it. so thank you so very,very much.
Sep 29, 2017 at 2:28 AM
SATURNTECH9
  • 30,869 POSTS
Yeah a body control module controls those gauges and the security system on the car.Thats why I say it sounds like a bad body control module.They have a high failure rate.They used to have a person on eBay that repaired them.
Sep 29, 2017 at 6:18 AM
DESERTLADY
  • 9 POSTS
Thank you, you have been so much help to me. I will now get a body module control. I have pulled out my glove box and I see it right on top of it with only 4 plugs. Thank you so very much. Have a great day. Desert Lady
Sep 29, 2017 at 8:10 AM
SATURNTECH9
  • 30,869 POSTS
The new body control module has to be programmed to your car with the correct miles etc
Sep 29, 2017 at 3:30 PM
SATURNTECH9
  • 30,869 POSTS
I would find a place that repairs them that way no programming and mileage won't be effected
Sep 29, 2017 at 3:31 PM
