The engine cranks off of the key but won't the coil does not fire does get fuel but it can be pull started an fires up an runs perfect I have changed the distributor + cap an rotor, the coil, the ecm, the ignition switch, I have re grounded wires from body to engine from engine to the battery an from the battery to the body now an then after pull starting it it will start off the key may start all day then it just stops again until I pull start it again please any info or suggestions would be greatly appreciated thank you
Dec 27, 2014 at 2:45 PM
