Hello when I click on it, it just brings up code Nissan DTC 1 I will do further testing from video.
Apr 17, 2025 at 3:40 AM
YANNI CRISANTOS
MEMBER
Hello, seems to be a fuel issue, put some starter fluid on air intake and started it and then died off. Fuel pump seems to be working. Not sure what to do next.
Apr 19, 2025 at 12:06 AM
✓Experienced Mechanic
You are using an OBD2 scanner, correct? Because "1" is not a code, you may have a bad PCM, have you checked all fuses with the key on?
