Cranks but no start
70,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
GURU1847
Sat extreme cold went to start cranks over no start. gave code for crank sensor, replaced no codes now. still no start.
Feb 13, 2021 at 1:36 AM
That is interesting that you had a crank code and do not now and still does not start.
Here is a guide that will get us started:
https://youtu.be/dCjmRL3p4Cs
Did you check for codes after you cranked the engine? Or did you replace the crank and clear the codes and because it cleared, we are assuming it is not still there? Sounds silly but we just need to make sure you checked again for codes after you tried to crank the engine.
Next we need to pull a spark plug out and make sure it is not fouled. If you had a no start issue and the crank was the issue then it may have soaked the plugs and they are now failed due to fuel soak. So you may have fixed the issue but still have a no start because your plugs are fouled.
I would suggest changing the plugs and retesting. Here is a guide that will help with this. Plus I attached the info below on how to change them.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Let me know if you have questions.
Feb 14, 2021 at 7:44 AM
GURU1847
I replaced the crank sensor and cam sensor cleared codes. Crank over and over p0016 and p0017. Came back pulled plugs didn't look wet.
Feb 15, 2021 at 3:38 AM
Okay. Has there been any history to this? You have Cam Crank Correlation codes for both cams on bank 1. That means it is either out of time or we have an issue with the cam actuators on that bank.
Have you had the timing chain or any other head work on that bank?
Feb 15, 2021 at 10:32 AM
