Cranks but no start
126,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JUNIORDRITSAS
  • 14 POSTS
Hello, one morning went out, truck would just crank, I changed the fuel pump relay, truck started after stepping on the pedal, then it was good all week, after the week it did the same thing all over, just would crank.. Any help would be appreciated...Oh yeah, when the key is on, the oil pressure gauge moves around a little...
Sep 16, 2021 at 10:55 AM
SQM
  • 6,383 POSTS
Can you hear the fuel pump with the key to the on position?
If you can hear the pump then you need to see if you have fuel pressure. In case a faulty regulator is causing the issue.
You should have 9-13 PSI of fuel pressure with the key on and engine off.
https://youtu.be/aITQclp7zIE
Let me know what you got.
Sep 16, 2021 at 2:33 PM
JUNIORDRITSAS
  • 14 POSTS
Yes, I can hear the fuel pump from the tank with the key on...
Sep 17, 2021 at 1:00 AM
SQM
  • 6,383 POSTS
So if the pump is coming on then you need to check the fuel pressure. If the pressure is low then you could have a bad regulator or could be a restriction in the line.
Have you already checked to see if you have spark?
Sep 17, 2021 at 2:35 AM
JUNIORDRITSAS
  • 14 POSTS
Checked it today, I do have spark on number 1 plug...
Sep 19, 2021 at 12:22 PM
SQM
  • 6,383 POSTS
Make sure you are getting fuel. It should be 9-13 PSI with the key on and engine off.
Sep 19, 2021 at 12:44 PM
JUNIORDRITSAS
  • 14 POSTS
I was told that the ignition control module controls the injectors, is that true??
Sep 19, 2021 at 2:16 PM
JUNIORDRITSAS
  • 14 POSTS
It doesn't seem to be getting fuel, have buzzing from the tank from the fuel pump though..
Sep 19, 2021 at 2:18 PM
SQM
  • 6,383 POSTS
The ignition control modules provides spark to the plugs, it does not control the fuel pump or fuel flow.
So you said you can hear the pump with the key to the on position?
If the pump is coming on but you do not have proper pressure, it could be due to a clog in the line, could be a fuel filter that is jammed or a bad regulator.
Sep 19, 2021 at 2:37 PM
JUNIORDRITSAS
  • 14 POSTS
What exactly does the fuel pump relay do??
Sep 20, 2021 at 3:54 AM
SQM
  • 6,383 POSTS
The fuel pump relay provides power to the pump. If the relay is bad then the pump will not get any power and will not turn on. So if you can hear the pump come on the relay should be good.
Sep 20, 2021 at 4:08 AM
JUNIORDRITSAS
  • 14 POSTS
What's weird is what I started out with, wouldn't start, then I changed the fuel pump relay then it started, but only lasted a week..
Sep 20, 2021 at 5:35 AM
SQM
  • 6,383 POSTS
Interesting, so on the last time did you hear the fuel pump come on?
Have you got a chance to check the relay this time?
Here is a way to test the relay just in case:
Sep 20, 2021 at 5:48 AM
JUNIORDRITSAS
  • 14 POSTS
Yeah, I couldn't find where testing the relay was at on the page...
Sep 20, 2021 at 6:53 AM
SQM
  • 6,383 POSTS
Sorry about that. I have sent you the wrong link. Try this please:
Thanks.
Sep 20, 2021 at 7:58 AM
JUNIORDRITSAS
  • 14 POSTS
Yeah, I just went out and squirted some gas in the carburetor, I get nothing...
Sep 20, 2021 at 9:01 AM
SQM
  • 6,383 POSTS
If spraying fuel does not start the engine, then you might not have spark. As you know the two of the basics for engine start is spark and fuel.
Do you know if you are getting spark to the plugs. you can just pull one of the plugs and crank to see if it sparks.
And also if your pump is coming then it should be getting some fuel.
Lets take a step back, let me know what you have tried so far, this way we can figure out the next best step.
Sep 20, 2021 at 2:48 PM
JUNIORDRITSAS
  • 14 POSTS
Well, I went out and bought a cap and rotor, ignition control module, going to put them in today..
Sep 24, 2021 at 4:21 AM
SQM
  • 6,383 POSTS
Let me know how it turns out.
Sep 24, 2021 at 5:27 AM
JUNIORDRITSAS
  • 14 POSTS
Sorry for the delay, but kind of stayed away from the truck for some time, today I swapped out the fuel relay, got it running, but went out a hour later, no start, only when I stepped on the gas pedal...
Oct 19, 2021 at 1:52 PM
SQM
  • 6,383 POSTS
So, what is it doing now? Does it just carks over and not start?
Can you hear the fuel pump kick in?
Oct 19, 2021 at 2:01 PM
JUNIORDRITSAS
  • 14 POSTS
It'll run if you give it gas with the pedal, yeah I can hear the fuel pump..
Oct 20, 2021 at 3:07 AM
SQM
  • 6,383 POSTS
It does sound like the engine is not getting enough fuel. It could have a restriction on the line. Like a clogged fuel filter or a bad regulator. Only way to tell is by testing the fuel pressure. Did you say that you checked the fuel pressure?
Oct 21, 2021 at 12:54 PM
JUNIORDRITSAS
  • 14 POSTS
I changed the cap and rotor, wires and she fired up. There was a bunch of white powder inside the sill of the distributor...
Oct 23, 2021 at 2:26 AM
SQM
  • 6,383 POSTS
The white power is aluminum oxide, it forms over time due to high voltage arcing the gap from the rotor to each post on the cap.
Glad it is running.
Oct 23, 2021 at 1:33 PM
JUNIORDRITSAS
  • 14 POSTS
Yes so far so good, thanks for all your help...
Oct 24, 2021 at 10:07 AM
SQM
  • 6,383 POSTS
You are welcome.
Oct 24, 2021 at 10:23 AM
