Engine cranks but will not stay running?
24,000 MILES • 3.5L • V8 • 2WD • AUTOMATIC
SUE MARCUM
  • 6 POSTS
Put a little gas in the carburetor and it hits but won't run. Runs just second and shuts off.
Sep 12, 2022 at 6:19 AM
  • 110,248 POSTS
Hi Sue,
You have already identified the problem. It is certainly fuel related. If I recall, in 1986, these vehicles had a mechanical fuel pump. If you follow the fuel line from the carb, it will lead you to the pump. If it's fuel-injected, it's a different story.
Here is the issue. In 1986, it appears the vehicle could have come with either an electrical or mechanical fuel pump. Does the vehicle truly have a carburetor or is it fuel injected?
Sep 12, 2022 at 12:23 PM
