Cranks but no start?
120,000 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
VAN OSSIE PETER
All sensors have been replaced, the crankshaft angle sensor in the distributor has been replaced. but can't find the crankshaft sensor on the bell housing. This is an Automatic is there a second crankshaft sensor on the vehicle listed above R50 model.
Jul 10, 2023 at 2:29 PM
  • 55,849 POSTS
Will the engine run on starting fluid? If not, we need to check for spark, this video can help. Also, when you turn the key on without cranking the engine over can you hear the fuel pump run in the tank for about 5 seconds?
https://youtu.be/baq_aEWNQ0Y
Please go over this guide as well:
https://www.2carpros.com/articles/car-not-running-advanced
here is the location of the crankshaft sensor. Check out the images (below). Please let us know how it goes. Does this engine have a distributor or no?
Jul 11, 2023 at 10:19 AM
VAN OSSIE PETER
Yes, and the rotor button and crankshaft positioner have been replaced.
Jul 12, 2023 at 3:16 PM
  • 55,849 POSTS
I am sorry I don't have a better image for you, this is all it says:
Crankshaft Position Sensor (OBD) On transmission housing, facing flywheel gear teeth. See Figure .
Does the engine have spark? If so, the crankshaft sensor is not the problem.
Check out this video:
Please go over this guide and get back to us.
Jul 13, 2023 at 2:59 AM
