Cranks but no spark and will not start
200,000 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
MOORE1645
My car was running and it was missing and it quit and now it will not start. We changed coil ignition last year. We put a new crank sensor on. We have fuel and good air compression. Any suggestions?
Nov 10, 2017 at 9:41 PM
KHLOW2008
  • 41,812 POSTS
Hi Moore,
Are you getting power supply to the ignition coils? Did you replace all the coils? Did you check for trouble codes? Are the crank sensor wires in good condition and is the connector clean and tight?
Nov 10, 2017 at 10:54 PM
MOORE1645
Yes and we replaced all. We had one that was working prior to the car breaking and we tried it and still no spark. We checked for codes and none. Crank sensor wires are in good shape and they have less than one ohm resistance to ECM.
Nov 11, 2017 at 12:39 AM
MOORE1645
It has no power to fuse 40, 41, 42.
Nov 11, 2017 at 4:36 AM
MOORE1645
We fixed the power to the fuses, but car still does not start. We have no injector pulse and no spark.
Nov 11, 2017 at 10:13 AM
KHLOW2008
  • 41,812 POSTS
What was the cause for missing power supply?
This could be a fault with the relays, ignition control or main relay.
Could be some wire connector is loose somewhere or a ground wire is bad if battery voltage is available at coil and no spark.
Nov 12, 2017 at 12:51 PM
