Engine shut off while driving
176,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
GEERTZE
while driving truck shut off. cranks but does not start. It has 65 lbs fuel pressure and spark, no codes. would a crank or cam sensor cause this? I did try a different ECM and checked all the fuses.
Jan 26, 2018 at 4:59 AM
Good morning.
Did you put the original PCM back into the truck? Does the check engine light still work with the key on?
When you crank the engine does the tachometer move up a little showing rpm reading?
Also, remove one plug and check the compression. lets make sure the timing chain is in time.
Jan 26, 2018 at 8:31 PM
GEERTZE
not the original PCM and yes the tachometer does move a little. I will check the timing.
Jan 26, 2018 at 11:18 PM
if the tachometer moves while cranking, the crank sensor is working.
the swap on the PCM, did you have it flashed to your truck? it needs to see the VIN from your truck to properly work.
Jan 26, 2018 at 11:41 PM
