Cranks but does not start
1,234 MILES
MISS DARCY
two weeks ago I had to change my gas filter, gas pump and clean the gas tank out. drove it for a few days and now it won't start. it just cranks, but don't start. what do I do?
Aug 17, 2020 at 10:01 PM
Good morning,
Can you hear the fuel pump run when you turn the key on? I would check the pressure.
When you crank the engine, does the tachometer move up a little showing RPM? That will tell me if the crank sensor is working.
Is the check engine light on?
Mar 6, 2021 at 4:19 AM
MISS DARCY
I think yes you can here the pump turn on and picture of engine shows and I need to look on to see if gauges move.
Okay, do the tests I suggested and then we can get closer to the area of failure.
MISS DARCY
I don't know how do. never mind thanks. I just need help.
I want to help but I need to know certain things. I am here and not there and you are my only contact and I need this information to help.
Read the guides as to how to perform the procedures.
