cranks but does not start
135,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
TONYINBELIZE
my car listed above 2g (420a engine) cranks but will not start. i have changed the crank shaft position sensor and also the ignition coil. it has fuel pressure but none of the injectors are firing. I was told that the car's main computer is to blame, but i am not too sure. i was wondering could the computer be the problem or could it be something else?
Mar 21, 2018 at 5:49 AM
CARADIODOC
  • 34,415 POSTS
The more common suspect would be the camshaft position sensor, but the place to start is by reading and recording any diagnostic fault codes. Often codes for those sensors do not set just from cranking the engine. They usually need more time to be detected, as when a stalled engine is coasting to a stop. When there is no fault code to direct you to the circuit that needs further diagnosis, you can use a scanner to view the sensors and see which signal is not showing up at the engine computer.
Mar 21, 2018 at 10:51 AM
RENEE L
  • 1,260 POSTS
Hello TONYINBELIZE,
I am sending you a link that if you decide to conduct the scan yourself it will be a great help to you. The link features an article with written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the code number(s) please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Mar 22, 2018 at 7:12 AM
