Cranks but does not start
120,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
BILLIDEAL
Has spark at plugs, but no fuel going to fuel rail. I pulled fuel pump, pump spin on bench?
Sep 21, 2018 at 3:43 AM
  • 110,248 POSTS
If the pump runs, it still may not be producing enough pressure to run the engine. Since you already have the pump out, you will need to check the electrical connections on the car to see if there is power to the pump. It runs on a bench when you supply power, but it may not be getting power in the vehicle.
If there is no power, check the fuel pump relay located in relay box in the vehicle Here are the directions for testing the relay. The pictures attached correlate with these directions. The directions are straight forward.
__________________________
FUEL PUMP RELAY
Check continuity between terminals 3 and 5.
If NG, replace relay.
Next, the oil pressure switch can shut down power to the relay. I've attached a picture of its location. Make sure the connection is good, clean, and tight. I also attached a picture of the fuel pump relay's location (pic 4).
The last picture correlates with these directions. It's to check the pump. Make sure it meets the specs listed.
FUEL PUMP
1. Disconnect fuel pump harness connector.
2. Check resistance between terminals 1 and 3.
Resistance: 0.2 - 5.0 Ohms [at 25 °C (77 °F)]
If NG, replace fuel pump.
Let me know what you find or if you have other questions. I hope this helps.
Sep 21, 2018 at 12:26 PM
BILLIDEAL
Car does not start but cranks turns over. Fuel pump pulled and benched tested and does spin.
I got the following scan codes:
P1320
P0110
P0180
P0420
P0430
P0464
Oct 9, 2018 at 10:10 AM (Merged)
