Cranks and fires but will not start
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ANDREW LANE
My SUV will not start. It has good spark and is getting plenty of gas but still will not start. I can here the engine fire as it cranks but it will not keep going and sometimes sputters a little bit after I stop turning the key. Also, it will not completely connect to code reader. Will not scan catalytic converter, EVAP, o2. says there are emissions related engine DTCS but will not list. Any ideas?
Jan 15, 2018 at 6:00 AM
CATAFINA
  • 98 POSTS
Check your fuel pressure.
Go here: https://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
Jan 15, 2018 at 9:37 AM
ANDREW LANE
Fuel pressure is 60 psi.
Jan 15, 2018 at 6:10 PM
  • 55,845 POSTS
How does the engine sounds when it is cranking over like it has compression? Here is a guide to help us confirm.
Cheers, Ken
Jan 19, 2018 at 3:28 AM
