Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
C1500
Engine
Symptoms
Not Cranking Over
Cranking, like it is not getting fuel?
1998 GMC C1500
30,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
ABIGAIL CRUM
MEMBER
1 POST
Had injector replacement and distributor and fuel filter ran good for little while.
Nov 8, 2022 at 11:29 PM
Experienced Mechanic
A weak fuel pump can cause this problem, but to be sure we can do a fuel pump pressure test which can be done by following this guide:
Pressure 55-60 PSI
Open Throttle - 66 PSI
Has the spider injector been replaced with OEM? Check out the images (below). Please let us know what you find. We are interested to see what it is.
Image (Click to enlarge)
Nov 9, 2022 at 3:40 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
