Cranking but will not turn over
136,000 MILES • V6
WALIK
I changed the crank sensor and ECM car was running fine now it will not start. It cranks and shuts off.
Feb 13, 2018 at 10:09 AM
SATURNTECH9
  • 30,869 POSTS
With the key in the run position is the security light on solid or flashing on the dash?
Feb 13, 2018 at 11:29 AM
WALIK
Solid.
Feb 16, 2018 at 9:14 PM
  • 55,748 POSTS
It sounds like you will need to have the new sensor programmed in the PCM. A shop can do it for you for about $65.00.
No spark right?
Cheers, Ken
Feb 19, 2018 at 4:19 AM
