cranking but not starting put gas in it?
130,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JAYMELYLES48
replaced serpatine belt then tried to start it it just continuosly cranks put gas in it replaced and checked all relays and fuses don't know why it will not turn over
Feb 24, 2026 at 3:19 PM
  • 55,732 POSTS
So by the serpentine belt is the crankshaft position sensor. If the old belt took out the wiring the engine will not start, here is a video to show the sensor and location so you can check it out.
https://www.youtube.com/watch?v=_xoGyRrHYbM&pp=0gcJCaIKAYcqIYzv
If the sensor looks okay we need to go over this video to see which system is failing so we don't go down the wrong trail. ie, compression, fuel or spark.
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Please upload a short video in your response of the problem, so I can see what's going on. Please go over these guides and get back to us.
Feb 25, 2026 at 1:00 AM
