There is no way to diagnose the problem with no test results to analyze, and I do not know which engine you have, but I can offer some suggestions. First, on any brand of car it is fairly common for a crankshaft position sensor or a camshaft position sensor to start to fail by becoming heat-sensitive, then they work again after they cool down for about an hour. Once the engine is running again, natural air flow while driving usually keeps them cool. They tend to fail after the hot engine has been sitting for a while.
The clue to this failure is you will be missing spark and fuel pressure. A lot of people get hung up on the first thing they find missing and troubleshoot the wrong circuit. Fuel pressure can be misleading because the fuel pump will still run for one second when the ignition switch is turned on, but it will not continue running during engine cranking. That one second is enough to get the pressure up to where it appears to be okay.
The next thing is you need to read and record any diagnostic fault codes. Chrysler makes doing that yourself easier than any other manufacturer. Cycle the ignition switch from "off" to "run" three times within five seconds without cranking the engine, leave it in "run", then watch the numbers appear in the odometer display.
Dec 20, 2016 at 9:52 AM
