The engine is cranking but no starting?
97,540 MILES • V6 • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Hello, the Vehicle's model is GLS 450. The engine is Cranking but not starting. There is fuel with good pressure but there is no spark in the cylinders.
What could be the cause?
How can one diagnose further from here?
Apr 12, 2025 at 11:19 PM
BLESSING EWOBOR
  • 753 POSTS
Hello, could I also have the circuit diagram for the engine management?
Apr 13, 2025 at 3:52 AM
  • 55,770 POSTS
I would start by running the codes using a CAN scanner, also you might want to use an engine scanner so you can see if there is an RPM signal when cranking which should be about 200 RPM. This will tell us if the crankshaft sensor is working.
Here are two videos to go over to help us get started:
https://youtu.be/u-4syLc-ifQ
and
https://www.youtube.com/watch?v=dCjmRL3p4Cs&pp=0gcJCX4JAYcqIYzv
Please go over these guides and get back to us.
Apr 13, 2025 at 6:25 AM
