Crank will not start
50,000 MILES • 5.0L • V8 • 2WD • MANUAL
BERLYWOODS
My car will crank won't start.
Jul 18, 2020 at 12:17 PM
  • 110,248 POSTS
The first thing I suggest is to scan for diagnostic trouble codes. This vehicle has an OBD1 system which doesn't require a scan tool to retrieve codes.
Here is a link that explains how to get codes:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
If this happened all at once, then chances are it isn't getting spark or fuel. Here is a link that explains the most common causes of a crank no start condition. Take a look through it. It explains how to check for spark and fuel to the engine.
Let me know what you find.
Jul 18, 2020 at 12:36 PM
