Crank will not start
177,000 MILES • 4 CYL • 4WD • AUTOMATIC
RON CONDELUCI
About 3 weeks ago I had the starter replaced. Everything was okay until yesterday. Now the engine cranks good but will not start, also the temperature gauge will shoot all the way up to hot as soon as a turn on the ignition.
May 22, 2020 at 8:29 AM
  • 110,248 POSTS
As far as the temperature gauge, it sounds like there is a short to power. Do me a favor. I need you to test the oil switch. Here are the directions and the attached pic correlates with the directions. If you need help, let me know.
_____________________________
2003 Honda Truck CR-V 4WD L4-2.4L
Component Tests and General Diagnostics
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Oil Pressure Sensor Testing and Inspection Component Tests and General Diagnostics
COMPONENT TESTS AND GENERAL DIAGNOSTICS
Oil Pressure Switch Test
pic 1
1. Remove the YEL/RED wire (A) from the engine oil pressure switch (B).
2. Check for continuity between the positive terminal (c) and the engine (ground). There should be continuity with the engine stopped. There should be no continuity with the engine running.
3. If the switch fails to operate, check the engine oil level. If the engine oil level is OK, check the engine oil pressure. If the oil pressure is OK, replace the oil pressure switch.
____________________________________________
Next, I need you to check for spark and fuel to the engine to help determine why it won't start. The easiest thing to do is see if it starts for a couple seconds using starting fluid. If it does and then stalls, then we know it's a fuel related issue. If it still doesn't, then it's likely ignition related.
If you feel uncomfortable using starting fluid, here are two links that explain how to check for both:
Let me know what you find.
Mar 11, 2021 at 10:23 AM
Let's do two things. First we need to check for codes. I suspect we have an issue when the coolant temperature sensor is faulty telling the PCM that the engine is hot and it is not dumping the correct amount of fuel so the engine will start. If we have codes then we can track down that issue and is not, we can just go after the coolant sensor on our own and then once that is fixed we can retest the starting issue.
Here is a video that covers the basic things of a no start but again, let's go after the coolant temp sensor first and then we can address the no start if that does not fix it as well, which will be checking for spark and fuel.
https://youtu.be/dCjmRL3p4Cs
RON CONDELUCI
Kasekenny1,
I was able to get the engine to start by using starting either, but the temperature gauge still was pegged. Since it was running, should I still go after the temperature sensor. Also, there is no check engine light coming on.
  • 110,248 POSTS
If it starts with starting fluid, replace the sensor to see if that takes care of the problem. Is the vehicle able to be restarted without the use of starting fluid?
RON CONDELUCI
No, it will not start without using the either.
The way I understood this was the temperature gauge issue happened at the same time as it started to not start. If this is the case then I would think the PCM is cutting the injectors due to it thinking the engine is overheating. If these issues are related, then doing as Joe stated of replacing the sensor would fix both issues.
However, if it doesn't then we can chase the fuel issue because clearly it is not getting fuel causing the no start.
RON CONDELUCI
Okay, thanks. I'll get it started again and take it to the repair shop. Where the sensor is located I can't do it at home.
While the sensor is the most likely cause of this, it could be a shorted wire. If it were me, I would replace the sensor and go from there. They are pretty cheap which makes it worth while to just swap it out.
Here is the info on the sensor. Let us know what happens. Thanks
RON CONDELUCI
Thanks, I'll let you know.
  • 55,684 POSTS
RON CONDELUCI
In the diagram where is the coolant temperature sensor?
Sorry. It is circled in this attachment. Called the ECT for engine coolant temperature sensor.
It is actually behind the black electrical connector. I pointed in red to the wiring for the sensor.
Let us know if you still can't find it and we will see if we can get more detail.
RON CONDELUCI
Is it on top of the engine and is this diagram showing the front or side of the engine? I found it, but I can't reach it without removing the black electrical connector. It looks like a black rail about 12 inches long. Do I remove that?
  • 110,248 POSTS
Here are the directions for replacing the sensor. The attached pic correlates with the directions.
Procedures
Vehicle Sensors and Switches Sensors and Switches - Cooling System Engine - Coolant Temperature Sensor/Switch Service and Repair Procedures
PROCEDURES
ECT Sensor Replacement
1. Remove the air cleaner.
2. Disconnect the ECT sensor 2P connector.
pic 1
3. Remove the ECT sensor (A).
4. Install the sensor in the reverse order of removal with a new O-ring (B).
_______________
Let me know if this helps. Also, the sensor is below the component you mentioned. You shouldn't need to remove it.
RON CONDELUCI
Hi guys,
I was able to get to and replace the sensor and it fixed the problem. Thank you very much for the excellent guidance through the process. Job well done.
Thanks again.
Ron
  • 55,684 POSTS
JACOBANDNICKOLAS is one of our best! Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
RON CONDELUCI
I have another problem with a different vehicle. This is a 2009 Hyundai Sonata with a 2.4 cylinder engine. The engine started to sputter while driving and would bog down when I tried to accelerate. I was able to nurse it home and now it cranks but won't start. I seems like I have spark but no fuel delivery. I suspect the fuel pump?
  • 55,684 POSTS
Please post your new question here, you must be logged in:
Cheers, Ken
