Crank will not start
188,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
RON SULLIVAN
I replaced fuel spider ran good for a few days then running rough and cutting out.
Can any one help me? Not turning over no start. Will start with starting fluid.
Nov 16, 2018 at 11:02 PM
  • 110,248 POSTS
If it starts with starting fluid, then it is fuel related. Have you checked pump pressure at the injector? That is where I would start.
Here are the manufacturer's specs:
Start engine and observe fuel pressure reading. It should be 400-440 kPa (58-64 psi).
Do this and let me know what you find.
Nov 17, 2018 at 9:45 AM
