Crank sprocket
130 MILES • 2.7L • V6 • AUTOMATIC
DESTINY OUSLEY
The timing is fixed, how do I remove the bolt in sprocket, so I can put the pulley on?
Jun 7, 2019 at 1:41 PM
SCGRANTURISMO
  • 4,897 POSTS
In the diagrams down below I have included the removal and installation instructions from the factory for your vehicle's crankshaft pulley or harmonic balancer. Please go through this guide and get back to us with what you find out. I sometimes use a breaker bar and figure out the rotation of the engine. I then rotate the breaker bar with a socket on the bolt and wedge it against something on my car that won't be damaged by a jolt. I then "bump" my engine and let the engine break the bolt free. Whatever you decide to do let us know how it turns out.
Thanks,
Alex
2CarPros
Jun 7, 2019 at 3:26 PM
DESTINY OUSLEY
I already have the harmonic balancer off, I need to put it back on, but the bolt is in the sprocket from setting the timing, and I’m trying to figure out how to get it out without an impact.
Jun 7, 2019 at 11:23 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
I would refer you to the latter part of my last answer. I've done this more than once. It works.
Thanks,
Alex
2CarPros
Jun 8, 2019 at 7:48 AM
