Slow cranking
118,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
CONRADISH006
  • 53 POSTS
My alternator was bad so I replaced it and I have a 1-year old battery. But my starter tested fine. But it cranks really slow.
Jan 29, 2019 at 2:18 AM
SEVAG P
  • 405 POSTS
-first charge your battery. https://www.2carpros.com/articles/how-to-charge-your-car-battery
-check the battery if its in good condition(load test) run our guide: https://www.2carpros.com/articles/car-battery-load-test,
-check the battery cables and clean them:https://www.2carpros.com/articles/everything-goes-dead-when-engine-is-cranked.
-check starter connection if the nuts are tight and clean
-check the engine ground if its clean and properly tightened.
-perform voltage drop test good connection should have voltage drop of 0.2v or less.
-to perform voltage drop test first prepare the car to not start when cranking by removing fuel pump relay, use digital voltmeter put the red terminal on positive post of the battery and the black terminal to the starter thick cable which is called terminal 30 +then crank the engine result must be lower than 0.2v if not problem can be from connection points or the cable.
-same test perform with voltmeter to negative post of the battery and starter housing.perform the same procedure.
Jan 29, 2019 at 3:28 AM
CONRADISH006
  • 53 POSTS
I have charged the battery and tested it. And the alternator connections are secure and rust free. It is also -2 degrees outside and the starter was tested after it had been it the house. So i am thinking that the starter doesn't like the cold.
Jan 30, 2019 at 7:49 AM
SEVAG P
  • 405 POSTS
Have you performed voltage drop test as mentioned above? high resistance cables can cause engine hard to start.
What type of engine oil are you using? high viscosity oil can cause the same problem.
Jan 30, 2019 at 1:24 PM
CONRADISH006
  • 53 POSTS
I have not performed a voltage drop test. And I am using 5w-30 full synthetic. As it recommends in the owners manual.
Jan 30, 2019 at 9:55 PM
SEVAG P
  • 405 POSTS
Perform voltage drop test and please tell me the result, really interested to know what's the problem.
Jan 30, 2019 at 10:40 PM
CONRADISH006
  • 53 POSTS
Okay.
Jan 31, 2019 at 1:06 AM
CONRADISH006
  • 53 POSTS
I am doing that this afternoon.
SEVAG P
  • 405 POSTS
Good luck.
Jan 31, 2019 at 1:12 AM
CONRADISH006
  • 53 POSTS
Thanks.
Jan 31, 2019 at 1:29 AM
SEVAG P
  • 405 POSTS
You are welcome.
Jan 31, 2019 at 3:28 AM
CONRADISH006
  • 53 POSTS
I did the voltage drop test and it did not drop below 0.2 volts.
Jan 31, 2019 at 10:53 AM
SEVAG P
  • 405 POSTS
When your value is more than 0.2 volts then you have bad connection or bad cable.
Jan 31, 2019 at 1:28 PM
CONRADISH006
  • 53 POSTS
I am going to replace the starter. It has 120,000 miles on it and i live in a cold climate.
Feb 1, 2019 at 12:54 AM
CONRADISH006
  • 53 POSTS
Sometimes its -5 in the winter and it is sometimes 100F in the summer.
Feb 1, 2019 at 12:56 AM
SEVAG P
  • 405 POSTS
Make sure your battery is in good condition because most of the time battery can effect from cold weather.
If you can run an outside cable from battery positive post to starter terminal 30 which is the thick cable and recheck if it doesn't make any difference replace starter.
Feb 1, 2019 at 1:46 AM
CONRADISH006
  • 53 POSTS
The new starter fixed it.
Feb 1, 2019 at 2:37 AM
SEVAG P
  • 405 POSTS
Very nice to hear that, have fun then, congratulation.
Feb 1, 2019 at 2:42 AM
