Crank shaft sensor bolt off in the block?
250,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
REY REED
Bolt is broke off in block?
Nov 28, 2024 at 11:56 AM
REY REED
Bolt is broke off in block will new one still work?
Nov 28, 2024 at 11:59 AM
STEVE W.
  • 15,404 POSTS
It's a common thing but to install the new sensor you need to remove the broken off piece of bolt. The first step in this is to plug the hole the sensor goes into then try the removal methods. To do that you will need to either drill out the broken piece so an extractor can be used or use a welder to weld a nut to the piece to remove it. The second one usually works better because the heat during welding tends to break any corrosion loose so the threads release.
This video shows a few methods of removal:
https://www.youtube.com/watch?v=x_ky5JVxtqU
Once you have the broken bolt out you can replace the sensor.
Nov 28, 2024 at 6:53 PM
