Crankshaft sensor
2010 FORD BANTAM
170,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
JOE TO BLOGS
When I turn engine over with starter takes 15 swings to start, but when I push start it starts immediately. It not getting spark when swinging.
Jan 7, 2021 at 12:20 PM
Just to confirm what you are saying, when you are using the key and turning it to the start position it cranks but finally starts after 15 cranks. When you push start it and pop the clutch, meaning you put it in gear and as it is rolling you let the clutch out with the key in the on position, it starts right away?
This is most likely due to a fuel issue. Either there is too much fuel in the engine when cranking or not enough. Let's start with checking the fuel pressure.
If the pressure is ok, then it could be a crank sensor but it is unlikely because if the crank was the issue the PCM would not know when to fire the plugs and just popping the clutch would not change that. So this tells us that by popping the clutch the CKP sensor is okay. However, here is a video of changing it on a Focus which is the same vehicle as yours if you would still like to inspect or change it.
https://youtu.be/_xoGyRrHYbM
Let us know this info and we can go from there. Thanks
Jan 8, 2021 at 11:24 PM
