crankshaft angle sensor
100,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
RAMBONNEE
Where is the crank shaft sensor located?
Jul 15, 2016 at 2:41 AM
HMAC300
  • 48,601 POSTS
Your car does not have one. see pictures to diagnose. pick up coil should have air gap of .008-,016" it can also be the igniter there is a separate test for that.
Jul 15, 2016 at 5:18 AM
RAMBONNEE
No wonder I was having such a hard time . Thanks a lot for the info .
Jul 15, 2016 at 2:06 PM
  • 55,694 POSTS
You are welcome please use 2CarPros anytime, we are here to help.
Best, Ken
Jul 21, 2016 at 3:18 AM
RONNIE ANTONIO
Hi Mr. Ken,
I need your help,am fixing a run down Toyota verossa 2001,I have had. a tough time finding wiring diagrams for the control box,the ECM is written 1JZ-FSE 5AT/TBS,please help
Aug 14, 2019 at 7:57 AM
RONNIE ANTONIO
Am trying to locate the crankshaft sensor connectors,the harness seems to have no provision.
Aug 14, 2019 at 8:07 AM
  • 55,694 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Aug 14, 2019 at 9:35 AM
