Where is the crank shaft position sensor located?
190,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JEZZM
Crank shaft position sensor location needed.
Aug 26, 2023 at 11:56 PM
  • 55,721 POSTS
Here are the location and the instructions on how to change out the crankshaft position sensor. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 27, 2023 at 8:58 AM
