If the problem still exists, then the issue is something else. Many times, the issue can be triggered by related components.
Jan 5, 2022 at 2:21 PM
ETHNWLSN40
MEMBER
The issues I’m having:
Engine misfires.
Stalls when idling.
Tends to misfire more when car warms up.
Error code I currently have:
P0335
Jan 5, 2022 at 6:50 PM
SQM
✓Experienced Mechanic
The code P0335 gets triggered when the ECM does not receive a proper signal from the crank sensor. It can be due to a sensor or faulty wiring. It can also be due to an issue with the ECM.
This will require a deeper dive to look at all the possibilities.
I have attached a trouble shooting guide for this code below. Go through this and that should narrow down the issue.
