Crank shaft position sensor
202,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KRAZY4X4S
  • 30 POSTS
My SUV is throwing a crank shaft position sensor code P0335. I was wondering where those are located on it? And what to test for are where to start to see if it is bad are not? thank you.
May 23, 2017 at 7:56 PM
HMAC300
  • 48,601 POSTS
yours has high resistance so just replace it and check connection. make sure to get the correct sensor as there are a few of them color match it. also, check for sludge buildup on end as that can cause it as well.
May 24, 2017 at 5:44 AM
KRAZY4X4S
  • 30 POSTS
Thank you very much. got it replaced everything looked good did not see any build up of sludge are anything else out of the ordinary.
May 24, 2017 at 8:52 AM
  • 55,743 POSTS
Here is the location and how to do it.
Please use 2CarPros anytime, we are here to help and tell a friend.
Cheers, Ken
May 26, 2017 at 11:19 AM
