Crankshaft position sensor and no spark?
4,800 MILES • 7.3L • V8 • 2WD • AUTOMATIC
DTPROBLEMS
Truck has low mileage and no spark. Changed plugs, wires and coils to no avail.
Oct 24, 2024 at 11:51 PM
  • 55,770 POSTS
I would scan for codes first. This video can help:
https://www.youtube.com/watch?v=InIlnsjOVFA&t=11s
Here is the crankshaft angle sensor so you can check it out and replace it if needed.
Using the scan tool, perform the Misfire Monitor Neutral Profile Correction procedure, following the on-screen instructions.
It looks like a ong sensor, and it is at the rear of the engine block. Check out the images (below). Please let us know what happens.
Oct 25, 2024 at 5:21 AM
