Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
All
Engine
Crankshaft
Replace/Remove
Crank shaft
2004 FORD
125,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
BIGBLUE65
MEMBER
1 POST
Can you break the crankshaft when replacing the motor mounts?
Jun 13, 2017 at 1:51 AM
HMAC300
Experienced Mechanic
I do not think so as mounts are external and crank is internal in engine.
Jun 13, 2017 at 5:08 AM
Add image or video
Ask a new question
