Replaced crank sensor and timing belt two days later is running poorly
112,000 MILES
SUEP
I had the crank sensor and timing belt replace due to a starting issue. Two days later my van is running awful. Now they want to do a tune up. I didn't need a tune up before they did the work. Did they do something wrong to cause my new problems?
Nov 21, 2019 at 12:22 AM
STEVE W.
  • 15,394 POSTS
What was the starting issue you had? What was the reason to replace the timing belt? Mileage or did it fail? I would have done a tune up at the same time myself if the plugs and such have unknown miles on them. Mainly because they would be an unknown item. Also a throttle body cleaning to ensure proper idle. Beyond that it is hard to say as parts can easily fail or it could be as simple as a loose connector that was removed when the other work was completed and it now is showing up. Exactly what do you mean with "running awful" misfiring, low power, poor mileage, doesn't start properly? Those may tell us more information.
Nov 21, 2019 at 1:36 AM
SUEP
The crank sensor was replaced to fix the starting issue. The timing and water pump and what ever goes with it was replaced because it was old. The van misfires and rough idle. I don't thin I should be charged for the work it takes to replace plugs again when he should have checked that when it was apart. He's talking another $450.00 tuneup. It didn't run bad before the work. It didn't always start. But it ran good. Thanks for your response.
Nov 21, 2019 at 7:16 AM
STEVE W.
  • 15,394 POSTS
Okay, if the parts were replaced for age and not failure but it was running good then they may not have touched the plugs to prevent issues. The owners manual info on that vehicle shows the plugs are a 60,000 service item. So at 112,000 if they were not changed they could easily be the issue. However they are known for the wires and coils as well.
To change them requires that the intake plenum be removed to gain access to the plugs, like many newer cars. The book shows about 2.5 hours of labor for the job. It's hard to say if they are worn out or if something else happened, What you might want to do is take it to a different shop for a second opinion. They should be able to tell if the parts were replaced or not. Might even ask a couple other places for prices on the same work. As I don't know the thoughts of the other shop I don't know what they did, however if they charged to for the tune up parts and now they think those are the problem now, it would depend on what they warranty and what they showed on the bill.
If you want to see what it takes here is a video on it. Shortened a bit in editing so you don't see the entire process.
https://www.youtube.com/watch?v=So17kyOkwIU
Nov 21, 2019 at 10:25 AM
TJKC258
If this just started with timing belt replacement...I think I would be looking at the timing belt install. 1 or 2 teeth will make a difference. Don’t mean to be second guessing someone’s work, but things happen.
Nov 22, 2019 at 8:21 AM
STEVE W.
  • 15,394 POSTS
True but it took 2 days for it to start running bad, timing belt should have showed up in the first ten minutes of driving.
Nov 22, 2019 at 9:15 AM
