Crank sensor location
2010 NISSAN TITAN
165,371 MILES • 5.6L • V8 • 4WD • AUTOMATIC
GREG SANDERSON
Would like to know where my crank sensor is. the code keeps coming up and it starts hard and chugs a little, but I can clear the code and start it and the light will not come on. it runs fine shut it off and start it again and the light will be on again.
Jan 15, 2021 at 7:03 AM
  • 110,244 POSTS
The sensor is located on the right side of the engine block. See pic 1.
Now, if I recall, this is a tight one to access (4wd). Take your time. You will need to remove the skid plates under the vehicle to access this. Also, the picture is looking up at the engine from under the vehicle and number 3 is pointing at the sensor.
Here is a link that shows in general how one is replaced:
I hope this helps. Let me know if you have other questions.
Jan 16, 2021 at 9:01 AM
