Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Geo
Tracker
Engine
Crankshaft
Sensor
Location
Where is the Crank sensor located?
1999 GEO TRACKER
10,000 MILES • 1.6L • 4WD • AUTOMATIC
ROBERTWHITAKER
MEMBER
1 POST
Crank sensor location needed.
Jan 25, 2023 at 7:21 PM
AL514
Experienced Mechanic
Hello, the crankshaft position sensor is just below the harmonic balancer on the front edge of the oil pan, I'll post a diagram.
Check for oil inside the harness plug for the sensor.
Images (Click to enlarge)
Jan 26, 2023 at 12:36 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
