replace the position crank sensor?
143,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
ALINE GUY
  • 5 POSTS
We recently replace the position crank sensor and now it acting up again. We are going thru a lot of oil and fuel and want to know what can cause us to keep having this problem. We also have a bad knock in the engine.
Mar 20, 2017 at 9:47 AM
STEVE W.
  • 15,409 POSTS
If you are using a lot of oil you may have internal engine issues. You will want to have a leak down test and a compression test done to see if you can find the problem. It could be simply carbon in the rings or bad valve seals. It may also be a result of the extra gas usage as that will wash the oil off the cylinders. With both of those you are not helping the converter so you should get that checked ASAP. When you replaced the sensor did you do a crank/cam relearn? What was the original crank sensor replaced for? Did you use an OEM replacement or? Some after market parts are not as good as the box they come in. Here is the location of the crank sensor and how to replace it in the diagrams below. Check out the diagrams (Below). Please let us know what happens.
Mar 20, 2017 at 9:58 AM
ALINE GUY
  • 5 POSTS
We replaced it because it left us on the side of the highway so we had the Jeep towed to the shop and they ran a diagnostic test and it came back that the sensor was faulty. And it was relearn as it was it safety mode but I do not know if he used after market parts or OEM like the first time. The Jeep lacked power the RPMs would rev out to like 6000 RPM but the Jeep would not move. My husband check the oil and it was down a few liters so he put more in we took it for a drive and the check engine light came on so we carefully drove it back home before it stop working all together were we needed a tow truck.
Mar 20, 2017 at 10:05 AM
STEVE W.
  • 15,409 POSTS
OK, Does the engine run but the Jeep will not move or is sluggish when put in gear? From the description of it revving to 6K but no motion that isn't the engine, that is the typical failure mode of the CVT transmission in the Patriot.
It sounds like you need to have a scan done to see what the code(s) that turned on the light are first. That will give you a starting point.
I hope I am wrong on the transmission, but they are very failure prone.
Mar 20, 2017 at 10:43 AM
ALINE GUY
  • 5 POSTS
If the transmission is what is failing is that what would cause the sensor to fail as well?
Mar 20, 2017 at 10:53 AM
STEVE W.
  • 15,409 POSTS
It should not but, it could be just a coincidence also. I would get it scanned with a factory level scan tool and look at the codes as well as check the indicators for the transmission. You could be fortunate and have it be something simple.
Mar 20, 2017 at 2:43 PM
ALINE GUY
  • 5 POSTS
Ok thank you.
Mar 20, 2017 at 10:22 PM
ALINE GUY
  • 5 POSTS
Well you were right Steve. It the tranny thank you
Mar 22, 2017 at 10:11 AM
STEVE W.
  • 15,409 POSTS
Sorry to hear that. I doubt it would do any good but you might call Jeep corporate and see if they will help in some way, like reduced pricing or free labor. Sometimes if you badger them about the problem they will do a goodwill type repair.
Mar 22, 2017 at 11:22 AM
CHUCK41969
  • 5 POSTS
I’m trying to find the location of the crankshaft position sensor. If you can show me a diagram of its location I would really appreciate it.
Jun 5, 2021 at 5:23 AM (Merged)
  • 110,248 POSTS
Welcome to 2CarPros.
Picture 1 below shows in general its location. I also included the directions for removal and replacement. It is easier to see location that way. The attached pictures correlate with the directions. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
2010 Jeep Truck Patriot 2WD L4-2.0L
Crankshaft Position Sensor - Removal
CRANKSHAFT POSITION SENSOR - REMOVAL
The Crankshaft Position Sensor is in the rear of the engine block near the transmission.
1. Remove the engine cover (1).
2. Disconnect and isolate the negative battery cable.
3. Remove the air cleaner body (1) See: Air Cleaner Housing > Removal and Replacement > Air Cleaner Body - Removal.
4. Disengage the upstream O2 sensor wire harness retainer (1) and crankshaft position sensor wire harness retainer (2) from the heat shield (3).
5. Remove one nut (1) and two heat shield retaining bolts (2).
6. Remove heat shield (3).
7. Remove the crankshaft position sensor mounting bolt.
8. Remove sensor with the wire harness attached.
9. Unlock and disconnect the electrical connector from the crankshaft position sensor.
INSTALLATION
1. Check O-ring for damage and lubricate the O-ring with engine oil before installing sensor.
2. Using a twisting motion, install the crankshaft position sensor.
3. Install the crankshaft position sensor bolt. Tighten the bolt to 9 Nm (80 in. lbs.).
4. Connect and lock the electrical connector to the crankshaft position sensor.
5. Install the heat shield (3) with one nut (1) and two heat shield retaining bolts (2).
6. Install the upstream O2 sensor wire harness retainer (1) and crankshaft position sensor wire harness retainer (2) to the heat shield (3).
7. Install the air cleaner body (1) See: Air Cleaner Housing > Removal and Replacement > Air Cleaner Body - Installation
8. Connect the negative battery cable.
9. Install the engine cover (1).
