Was starting hard, found the crank sensor was loose. tightened and ran good until hot. Misfires and runs terrible, will not even make a hill. the more gas you give the worse it runs. Sometimes if you let up a little bit it will smooth out and pick up speed until you move the gas pedal then it falls on its face. Like it is running on four cylinders.
Jan 23, 2017 at 5:32 AM
