The good news is I think AutoZone will rent/loan it out.
Jun 14, 2017 at 11:44 AM
DAVE HOWARD
MEMBER
I am using a pulley puller. Got it about 1/2" out. Think I need a larger puller.
Jun 14, 2017 at 11:50 AM
HARRY P
✓Experienced Mechanic
Yeah from what I can find out it should come out with the pulley puller. So it is definitely possible that you just need a bigger one. Or maybe you can substitute something in to use as a spacer, effectively making your puller bigger. Probably safer to just get the bigger puller though.
Jun 14, 2017 at 11:56 AM
DAVE HOWARD
MEMBER
Thanks, was using a 6" puller. Going to get me an 8" and back to the drawing board.
Jun 15, 2017 at 2:56 AM
Please let us know what happens :)
Cheers, Ken
Jun 17, 2017 at 10:17 AM
DAVE HOWARD
MEMBER
I got it out with the 8" pulley. Put the water pump in and now am having some trouble getting the timing belt back on. Have all the marks lined up and clipped. Have the belt on the crank pulley and trying to get it over the tensioner pulley. Took the tensioner back out and will retry to get the belt and tensioner back on. Very little slack in the belt.
Jun 18, 2017 at 4:00 AM
Make sure the new and old belt are the same size. The belt should go on without too much trouble, it sounds like you may have got the wrong one.
Cheers, Ken
Jun 19, 2017 at 3:02 AM
DAVE HOWARD
MEMBER
I got it on with a bunch of pulling, a pry bar on the tensioner pulley, a little rethreading, a few tightened here and there. Got the pulley bolt in finally. Feels snug, marks in the right spots.
Jun 19, 2017 at 1:20 PM
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Jun 19, 2017 at 2:09 PM
DAVE HOWARD
MEMBER
Any tips on getting the crank pulley back in? It's a heavy beast with a thick bolt and coarse threads, has a keyway. Thanks for the help.
Jun 20, 2017 at 3:14 AM
Yes, put the pulley in the over at 200 degrees F. Once warm it should go on the crankshaft easier. You will need gloves to take it out of the oven and to install it back onto the car.
