If you're referring to the harmonic balancer pulley (highlighted in the diagram below), the vibration dampener bolt should be about 7/8" in size. Using an impact air ratchet is usually helpful in removing that bolt. You will also need a puller tool to remove the harmonic balancer, which you may be able to rent from your local automotive parts store.
These repair guides show what is involved in removing the harmonic balancer:
https://www.2carpros.com/articles/how-a-harmonic-balancer-works
https://youtu.be/WITN7Q8SX1U
If there's anything else we can help with, please let us know.
Thanks, Wendy W.
Apr 12, 2022 at 4:03 AM
