Where are the crank position sensor and cam position sensor located?
150,000 MILES • 3.0L • 6 CYL
SHADOWENELI
Needing the location of the crank position sensor and cam position sensor in my buddy's car (listed above).
Jul 30, 2021 at 4:42 AM
SQM
  • 6,383 POSTS
Acura calls the cam sensor as TDC sensor and the crank sensor CKP sensor.
Please see attached diagrams for the location and replacement procedure.
Are you getting trouble codes related to those sensors?
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
https://youtu.be/hqEgqodE_-8
Jul 30, 2021 at 4:56 AM
