I need to know where the crank position sensor is on my car listed above. I can't find any videos online for the 2007. Can you help me?
May 9, 2020 at 12:54 AM
✓Experienced Mechanic
More then likely you are not finding it because it is covered by the lower timing belt cover. I attached the process and location. You will see it next to the crank pulley because clearly it needs to measure the crank rotation.
