Crank no start no fuel pressure?
198,000 MILES
MARK BLACKSTONE
Koeo key symbol upper right dash inside circle with slash is present.
PCM not rcv'd VTSS
Transponder commo failure
Sentry key immobilizer not received message
Code B366B-00
Code P1019-00
May 8, 2025 at 4:10 AM
  • 55,561 POSTS
Any response to this answer?
https://www.2carpros.com/questions/start-stop-button
The site works off of the conclusion of the problem? Can you answer back?
May 9, 2025 at 2:35 AM
MARK BLACKSTONE
Intermittent operation of start-stop button also radio continues to play and will not turn off after vehicle is supposed to be stopped.
May 9, 2025 at 3:40 AM
  • 55,561 POSTS
So the first code looks like a liftgate issue which should not affect the engine running. Please start a new thread for that if you want to have us help you fix it.
Code B366B-00 - Liftgate Ajar Switch Circuit
Code P1019-00 - Variable Valve Timing (VVT) Solenoid Range/Performance
The p1019 code may cause this but can I ask how the engine sounds while cranking over? Can you please upload a short video of the engine when trying to start it, that way I can tell if the engine is any good or not.
When you crank the engine over does the security light flash? If so, I would do a hard system reboot, this guide can show you how.
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
If the light is not flashing, please go over this video which shows the MAP sensor can cause this problem:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t=1s
Here is the location of the sensor so you can unplug it to see if it makes a difference.
May 9, 2025 at 4:19 AM
