Crank, no start, low voltage
160,000 MILES • 6.6L • V8 • 4WD • AUTOMATIC
ROBOTECH2
No or low voltage to cab. No interior lights, power windows and door locks not operating. Engine cranks and fires but shuts off immediately. DTC's are P 1626 and U 1026.Anti theft system is active and not getting fuel enable signal. The u 1026 code says no communication with ATC. Could my BCM be bad and if so what might be the cause? Batteries and alternator are new and charge is 100%.
Apr 24, 2019 at 9:35 PM
Good morning,
It sounds like the fuse block may not be allowing voltage to the interior.
Yes, the BCM controls the anti-theft but the BCM needs power to work.
Test for power to the under hood fuse block as well as the ignition switch.
Apr 24, 2019 at 10:03 PM
ROBOTECH2
I have power at the fuse block. And I have power at the fuse block in the cab.
Apr 24, 2019 at 10:26 PM
ROBOTECH2
Maybe a grounding issue?
Apr 24, 2019 at 10:27 PM
No, it is a power issue.
Check the ignition switch voltage.
Apr 24, 2019 at 10:39 PM
Did you respond? I got a notification but no response listed.
Apr 25, 2019 at 2:19 AM
