crank no start in a.m.
147,000 MILES
EDDIEU
  • 5 POSTS
spark good, fule 55psi and have injector pulse. no codes. t.p.s ok, rpm ok, coolant temp ok.after turning key off and back to start about 15-25 times truck will start and then start all day long no VTD codes i have replaced cap, rotor,wiers and pluges. This is a 4.3 v6 vin code W. when i pour fuel ioto throttle body engine will start how can i check fuel injectors
Jul 29, 2013 at 3:37 AM
JDL
  • 16,098 POSTS
With the spider fuel system pressure is 60--66psi, key on engine off. Also, the fuel poppets may need cleaning.
If fuel pressure drops like a rock with key off, you have a pressure leak.
Jul 29, 2013 at 5:04 AM
